Hi robinmdh,
I would be happy to. I will export when I get home.
As for the print job, it's any standard gcode that comes from my slicer (Cura 3.2.1 this time). What's interesting is that, after the reboot - sending the exact same job - it works perfectly. This has happened with multiple versions of Cura, going back a few versions now. I am just tired of not trusting it when I start it for the first time after a day off or so.
robinmdh 66
wow, that seriously sounds horrible!
Can you provide logs? and the first 100 lines of gcode or so (or the whole gcode)
Edit: logs can be dumped to a usb stick using the "SYSTEM->Maintenance->Diagnostics->Dump logs to USB" menu option.
Edited by robinmdhLink to post
