11 minutes ago, kmanstudios said:But I seem to remember that it was purge, then abort, and then it would not abort and then had to manually shut down
You may be right. Don't remember all the details.
Hasn't happened to me for a while until recently.
Wanted to report it as it is a bit annoying/unexpected and can hopefully be fixed.
kmanstudios 1,074
I remember the UM3X being stuck on a purge blob/priming blob once or twice. Just sat there and kept spewing out material without moving from the blob location or stopping. But I seem to remember that it was purge, then abort, and then it would not abort and then had to manually shut down.
I do not remember the filament going up the tube like your pic though.
None of that has happened since though.
