White filaments string more than most so keep that in mind. I have to print white filaments much cooler to avoid stringing. Try lowering the temp as it's printing and keep notes.
If you want really good quality (eliminating the line down the rear foot) then also lower the speed to 30mm/sec max. ALL the speeds - especially infill speeds. make sure the outer layer (shell) is the same speed because speed changes can cause tiny imperfections.
gr5 2,192
