Posted · Camera Ultimaker 3 Extended do not work
After the installation of Cura 3.2.1 and the last firmware, my printer's camera does not work anymore, any tips anyone? I really appreciate that!!!
Thanks
    go to http://<ip of your printer>:8080/?action=snapshot               -> You should see a snapshot
    go to http://<ip of your printer>:8080/?action=stream                   -> You should see a stream
    If this works try to reset cure connect in the menu of your UM3E. Maybe your printer just returns a wrong or no stream url
    I tried this and my browser cannot connect. Timed out
    I did have problems with the camera stream as well. Was able to resolve the issue by resetting Cura connect. You can do so by going to the maintenance menu.
    Somehow, after a reset this a.m.everything is kosher again.
    Strange, because I reset twice yesterday with no effect.
