Printing thin wall
daoust
Posted · Printing thin wall
Hi,  I m new to this forum and I use cura 3.2 for slicing my 3d project.
I created a calibration design for my printer.  My goal was to calibrate the flow of my extruder by printing a wall the same thinckness of my layer width (0.6mm)and nozzle width(0.6mm).  When slicing my parts,  the 0.6mm wall is not showing in the slicer so I enable the function,  printing thin wall ,  now I have my calibration wall but it look strange
My nozzle is 0.6mm
My setting in cura 3.2
Nozzle size is 0.6mm
Layer height 0.2
Initial layer height 0.3
Line width 0.6
Infill line width 0.6
The stl file was done with solidworks and also from cura with solidworks pligins
What can be my propleme
    Hello @daoust, sorry but you have hit a big problem with Cura that it doesn't make a good job of thin walls. The problem boils down to the fact that all walls have to be printed as a pair of lines and not just a single line. Cura tries to make amends by providing "wall overlap compensation" which makes a second wall that runs close to a first wall thinner so as to reduce the overall width but, unfortunately, the overlap compensation has many bugs and is not guaranteed to make a good job. It remains a problem area.
    So if,  I double the thickness of my wall from 0.6 to 1.2mm cura should be able to deal with it?  I  will give a try.  I have calibrated my e step on my printer and my filament diameter and now when I print some parts and my flow is at 100%  ,  my nozzle will grind the top surface when printing.  So I was pointed out that it was overextrusion.  From that point I realise that even if the extruder is well calibrated and the filament diameter was set properly,  I still need to calibrate for the density of the filament by setting the flow to a lower value .
    So if I print a thin wall of a set value like 1.2mm with a 0.6 nozzle and adjust the flow untill I really print 1.20mm,  is it a good way for calibrating my flow%?
    I have saw some trying to adjust by printing a small cube,  but I don t  belive that way is good because of the plastic retraction .
    If your "line width" is 0.6mm and your wall is 1.2mm it will do two passes next to each other and extrude the exact correct amount to make a 1.2mm wall.  No flow calibration necessary.
    The best way to calibrate your extruder is to extrude 100mm with no load and make sure the filament really moves that far.  If you have a bowden printer like an utimaker then start with the filament half way down the tube so there is no load.  If your extruder is only a few mm from the hot end then extrude very very slowly.  Or take the hot end apart so the filament isn't slowed by the hot end (maybe remove the nozzle?).
    You can use the feature "print thin walls".  I use this all the time and it works pretty well but you might get some underextrusion right after.  This will allow you to go down to a wall width about the same as line width.  I think you can print a 0.6mm wall with a 0.6mm line width but barely.  If you really need to print 0.6mm wall with 0.6mm nozzle then I recommend you enable "print thin walls" and set the line width to around 0.5mm or 0.55mm.  This works quite well.  I did this exact thing recently.
    It will extrude 0.5mm the first pass on the wall and on the second pass it will extrude only enough for the remaining .1mm (and move the nozzle just .1mm over to the side).  This works great except when it starts extruding a non-wall it will underextrude for a short period of time while it builds pressure back up.
    My extruder is calibrated that way and I still have some overextrusion even if my filament diameter is set at the real diameter.  So I need to play with the flow setting to reduce the overextrusion and I belive it because the density of the filament is diferent from on to another.  So by printing a thin wall,  I wish to set my flow corectly.  If you go back on top of the discution,  I explain my goal by printing a thin wall.
    Thank you
    Right.  Got it now.
    A third way to calibrate extrusion is print some "spaghetti" and then weight it.  e.g. print 100mm of filament and weight it.  Versus cutting 100mm of raw filament and weighing that also.
    Note that most extruders tend to slip about 10% so "normal" printing should underextrude by 10%.  That seems just wrong to me but that's the way it is.  It's not that the extruder motor is slipping - it's that there is enough pressure on the filament that the diamond shaped holes in the filament are positioned closer together than the diamonds on the feeder.  Because the filament is slipping or compressing or something.  By typically 10%.
    My printer is a creality cr-10s (bowden setup)  and I install a bondtech bmg extruder with a capricorn xs tube.   When calibrating my filament,  i ask for 100mm with my octoprint and it gave me exactly 100mm at 100% flow from my octoprint.  Octoprint works with a older cura slicer.  When printing  the benchy at 100% flow sliced on cura 3.2. ,  I have overextrusion .  My nozzle grind the print surface and I saw petg plastic filament that is release from the grinding (touching) stick to the nozzle. That s why I belive even if my extruder is well calibrated,  I still need to adjust my flow setting or maybe I miss something here.  I also belive that some filament will not have the same density that why I belive that It can be set with reducing the flow in my case.
    9 hours ago, gr5 said:
    ...  Because the filament is slipping or compressing or something.  By typically 10%.
    I once looked at the indents in the filament under a microscope. If the feeder wheel has square "pyramids" on it, the pits these pyramids leave in the filament get deformed (stretched) into diamonds-shaped pits instead of squares, in the feeding direction, due to the high force exerted on them. You might call it a sort of deformation, or "pit-stretching",or "partial slipping" indeed, but without grinding yet. Similar to car tires partially slipping, and starting to make sound, when braking hard but without locking the wheels up yet. The result is that the feeder wheel turns a little bit faster than the filament, due to this stretching-deformation of the little pits.
    I also guess this is why flexible filament needs a higher "flow rate" percentage than hard filament like PLA, to get the same correct extrusion? To compensate for more stretching of the pits?
    If you would calibrate the feeder with nozzle absent (and thus with very little resistance), the result would be different from with nozzle present (and thus higher resistance). Also, higher and lower printing temperatures, and higher and lower printing speeds (and thus higher and lower required forces to push the filament through the nozzle) would have an effect.
    This might actually be a good test: extrude 100mm of filament (=defined as 100mm), both with and without any resistance, and measure how much difference there is?
    (But of course there could still be other causes for deviations.)
    Ok,  I will try with and without to see the difference
    @geert_2 Actually, Illuminarti has done this test at multiple temperatures and speeds through a 0.4mm nozzle and he weighted the resulting "spaghetti" and this is what he discovered:
    The important graph:
    https://public.tableau.com/profile/illuminarti#!/vizhome/ExtrusionRates/Sheet1
    And the rest of the article:
    http://www.extrudable.me/2013/04/18/exploring-extrusion-variability-and-limits/
    I have allways use octoprint ti extrued 100mm od plastic fir my tunning,  is there a easy way to do it with cura?   Is it posible that octoprint don t have the same results as cura???
    For those who are looking for solution on this problem. Use minimal wall flow option set to 100% with compensate wall overlaps option.
    This way you will receive single line printing, the wall you are going to print must be slightly wider than nozzle. e.g 0.5mm nozzle -> 0.51mm wall
    #Cura print single line
    #Cura print thin wall
    I am new to Cura and have 4.0.0.  My nozzle is 0.4 mm and Wall Thickness is 1.2 mm.  I am printing a box with sides 2 mm.  I was hoping for Cura to slice this so that the nozzle makes 5 trips around the box for every layer.  What I got is two trips around the outside of the box, two trips around the inside of the box, and a whole lot of shaking (nozzle movement back and forth) to fill in the gap in the middle.  What settings do i need to get five trips arount the boz for each layer?
    If sides are 2mm then the wall is 1mm and you can do two trips if you set line width to 0.5 or 3 trips if you set line width to 0.333mm.
    Also to get rid of the "vibrating" set "fill gaps between walls" to "nowhere".
    Maybe you should show a photo of what you mean by "box with sides of 2mm".  You mean a box that is 2mm by 2mm, right?
    If you mean the box is much larger but you created walls in cad of 2mm then maybe you should just create a solid box in cad and turn off infill?  Maybe turn off top skin also?
    Here are two pictures showing this box being printed.
    In the first you see in this picture a box for a computer board to go into.  All the sides and the bottom of the box were designed to be 2 mm thick.
    In the second you see a close up view taken after the two outside and the two inside lines were printed.  When I took the second picture, the printer was doing the "shaking" to fill in between at the other side of the box.
    I want solid sides that are 2 mm thick.  Since the nozzle is 0.4 mm, then there should be five lines around the entire box.
    The printer will never ever do an odd number of lines in a wall.  Cura only makes loops.  Never lines that have a start and an end.
    So the fix is to use a line width that is an even multiple of that box thickness.  So for 2mm you can use line width of 0.5mm (which works okay with 0.4mm nozzle) or 0.333mm (which also works okay).  The former option is more likely to underextrude but will look better - I recommend doing that.  Actually I would try 0.49mm line width and turn off filling "gaps between walls"
    As far as the shaking, UM printers can shake like hell and it's all good.  It may not sound nice but after 2000 hours of shaking a UM printer will be still be fine.
