12 minutes ago, gr5 said:You need to cover the front and top of the printer. It's really important to stay above the glass temp for ABS on the bottom 1mm or so. Glass temp is about 99C for most ABS. And lower the fan to 30%.
This will give you an added benefit that the air temp will rise to about 35C (in addition to keeping the bed above 105C).
For now you can just use saran wrap or a clear plastic bag to cover the front and for the top use one of those boxes that used to hold many reams of paper. They fit the top of a UM2 or UM3 perfectly with no tape or anything needed and they leave room at the back for the bowden. Eventually, if you print a lot of high temp materials like nylon (abs sucks - i'd stay away) you should get a front door/cover.
Oh - and the 35C air temp is important also because if you don't do that you will likely get bad layer bonding (newer layers of ABS won't fully melt the layer below). Bad layer bonding isn't always obvious until you break it and notice it splits along layer lines. plastic should NEVER split along layer lines - they should be just as strong in all directions (no "grain").
So if I were to cover the printer and get an enviromental case or housing to seal it up a bit, that will obviously keep the air inside a more consistent temp, but how will that keep the build plate temp from falling? The printer is supposed to upkeep the temperature to what I set it to and it isnt...
gr5 1,554
