I don't have the equipment to see closer than the pictures show
@printedsolid is my source and perhaps they can find that answer
It is a blend of polymers. No particle fill.
I believe the satin finish, and the weird behavior where the material globs back on itself when you extrude into air, has to do with internal stresses in the material
I like the shine. Could be useful if you want to visually simulate metals, for example in a technical prototype, but without actually using abrasive metal-filled filaments.
Here's my review on it...plus a few suggestions/tips.
Le Paul
just got some of this Gold Rush Cant seem to get a decent print its leaving blobs at the start of a layer even in vase mode ?? any thoughts
Damn you!!! I had to buy some!! ?
9 hours ago, bob-hepple said:Le Paul
Hi
I used Simplify3D and used 215 for the first layer then 210 for the rest.
I didn't have any blobbing issues you mention. I bought 2.85 and 1.75 versions and for the latter, used it on my CR-10S using the same temp.
That first priming if the nozzle is so weird, as I mention in the video
I can't recall if I used Cura or not for any of the prints. My Ultimaker 2+ is down right now, I keep grinding up filament in the feeder....I think my TFT has finally gone bad on me so I have to replace that.
Hears the prints I have done with Gold Rush I wanted to use this to resemble polished brass for a model im printing the Results are terrible A Band had tobe adjusted so the the blobs could be hidden by a screw the others were don with variable setting I also printed hotter 215 to 210 which effected the over hang but I had no choice I cut down the flow which helped but no great improvements,, its worth noting the dual colour print worked fine but the was a flat and quiet small
so to re cap
this was done on dual colour printer
this was done on Ultimaker note the scaring around the hole if I rotate the band on the bed then scaring is still there just more visible
variable prints all bad all done at different temps and different extrusion rates
last picture shows the last print last night
temp 215 down to 210
14500 mm/min
ext multiplier 89
The filament is new purchased 4 weeks ago opened 4 days ago,, I was thinking if it needs drying but I thought that was if you got excessive stringing,, its weird stuff does not extrude out of the nozzle in a flow rate / congeals around the nozzle and comes out like worm crawling bulges then drops out, 215 seems to make it flow better but not much,, the Dual colour print was done at 205
going to print the above pic on Prusa mk3 in normal pla just to satisfy my curiosity,, any hints and suggestions gladly received except throwing the filament which I have come close to....
I did a test print in Cura now you have to remember I haven't used cura in years not even looked at it
the first one on the btm was done in cura same layer height 0.20 says one thing to me S3D need updating looking into the settings in cura it showed me how far its come, daunting though to learn a new slicer couldn't work out how to turn my Mark 2 second head off though...….
Doing my first test prints on the UM3E and so far, so good. The settings are basic PLA settings and seem to be working well. Will know more this afternoon. But I am happy enough I just ordered more for a variety of shades.
been quite happy with this stuff, this is the 'Merlot' Color
geert_2 543
Is this material particle-filled? It looks a bit like the shiny "mica" colours in some car paints, which use mica plastic particles. Maybe you can see it, if you look at the models through a microscope, or if you take a high-res photo through a good macro lens?
I did a quick google, but I didn't find much about the composition, except that it was "a blend of PLA and other polymers", which doesn't say much...
