Oh ! So I need to change the flow rate every single time I guess ?
They should update the Gcode flavor na ?
Thx for quick reply :3
If you change the gcode flavor (in Machine Settings), you have full control over all material parameters in Cura, including flow. But with power comes responsibility to make sure these parameters are correct for the material you want to slice for.
But I don't have the sweet little timer that tells me how long to wait if I change it... What a dilema ! ! !
I'll see on the go I guess !
Also, did you just make a reference to spider man or is it me ? reference :3
Or was I paraphrasing Theodore Roosevelt?
Edited by Carlitohehe, I guess we don't have the same reference ^^
I love the difference of cultur between a 15 and a 43 :3
tried to change the flow directly on the printer and it works flawlessly ?
Thanks !
ahoeben 1,886
The original idea with the UM2 family was to slice once and be able to print with different materials from that one sliced file. This means that all material-specific settings are controlled on the printer instead of in Cura.
Nowadays the consensus is that this was an interesting idea, but it doesn’t really work because different materials can require dramatically different settings (including eg different adhesion, support and infill settings) that could not be changed easily on the printer.
