Very frustrated with Ultimaker 2+ layer issues
Posted · Very frustrated with Ultimaker 2+ layer issues
Ultimaker 2+.  PLA    Using glue stick recently
I cleaned calibrated the printer but printing with it is a hit or miss
there is always the issue of under extrusion
sometimes this happens already on the glass surface
sometimes and mainly this append in the part
the printer was not used that much and worked perfectly before - was not used for over a year and a half
attached are some images to show the issue
i had the feeling this might be a feeder issue but mainly the test extrusion of material before printing looks amount wise fine
and also based on the nozzle and layer setting I get different results.
any help from Ultimaker would be highly appreciated
    Posted (edited) · Very frustrated with Ultimaker 2+ layer issues
    After this crap print
    590564054_ScreenShot2018-07-08at10_25_32PM.thumb.png.005e265c057782bbe00d1b0e3e2f1227.png1721291298_ScreenShot2018-07-08at10_25_37PM.thumb.png.4b97557fda20eb39bed06ac41c5d2ee1.png
    I calibrated the print bed again with the build in function and then with some test prints to check corners.
    216325492_ScreenShot2018-07-08at10_20_24PM.thumb.png.8287ce16222eb31a0b0ffa2a30b58bb5.png
    I had one 98% good print that showed only at two layers issues - which however is already not good
    1321169782_ScreenShot2018-07-08at10_28_27PM.thumb.png.a3dab01014e5938fada8d8eaf07c5390.png
    1005753678_ScreenShot2018-07-08at10_28_14PM.thumb.png.1ed1e2ab6e7fcabd40b28890aa32ed63.png
    and all following prints are horrible again. Below are two print attempts of the same mode ...
    IMG_1438.thumb.jpeg.6a53f49143bd983199b9d78ce65279e0.jpegIMG_1437.thumb.jpeg.91d69fb95ac7e06806173487fb6f98a6.jpeg
    @gr5 I am not sure if you could maybe point me towards a solution.
    Can the PLA be old or the print glass surface have issues?
    Edited by cekuhnen
    To me it looks like there might be multiple issues?
    I have the impression that the bed is too high, and thus the first layer is not squeezed into the glass enough and does not bond well?
    Maybe your bonding method also needs adjusting? For example if you use the glue stick, wipe it with a wet tissue after applying, to get a very thin layer? Or clean the glass and apply the bonding more often?
    And then of course there is underextrusion at irregular intervals, which could have lots of causes: partially blocked nozzle, too high printing speed, too low temperature, spool near the end and wound too tightly (this acts as a spring that resists unwinding), deformed teflon coupler, wrong feeder pressure, dirty feeder, wrong filament diameter, dirt in the bowden tube, or other things along this line...? But I am not familiar with the UM2+, so difficult for me to say, it is a bit of guessing.
    I did a test cube print and it failed too
    So I took off the print bed and washed it both sides and put it pack and the test cube print worked again instantly
    2D8C89E0-9A09-476C-ADBB-B9C7E228DC6E.thumb.jpeg.2ab9a753936a2ff0a2909b07888406d6.jpegCA745226-888A-476E-96B1-0D01282477BD.thumb.jpeg.b0bac6e9d3405c7005f2bb4ba7c704e1.jpeg
    Then i removed the parts to print the main design a s again this failure
    9A0F6298-E206-4D24-80D3-7BA37531E194.thumb.jpeg.1f81fcddedc039ffe88c51760525e845.jpegF29649D8-36E6-48BF-8D1F-A535356B9CD6.thumb.jpeg.7fc565af3015a1828a84c4af8c638758.jpeg
    this is just bonkers
    Printing the test cube again works
    Edited by cekuhnen
    Maybe I should not have praised the day before watching the even TV scheduke
    totally inacceptable layer gabs
    That's under-extrusion.
    Most likely caused by a blocked nozzle.  You need to do some atomic pulls to clean the nozzle.
    It also might be time to swap out the Teflon collar above the nozzle.
    you might also want to add more brim around your part,  I use 8mm.
    it will help with adhesion.  also check into 3Dlac spray,  works great,
    https://www.amazon.com/Adhesive-Warping-Printers-ORIGINAL-canNOT/dp/B01BVM54XI/ref=sr_1_1?ie=UTF8&qid=1531502759&sr=8-1&keywords=3dlac+spray
    It seems to me this was really more a feeder issue not nozzle or print plate.
    I have 2 0.8 nozzels (actually 2 complete nozzle sets) and the issue happens mainly with 0.8, less with 0.6 and hardly at all with 0.4
    I changed the tension and it seems to have helped.
    I will do another big print today.
    If it happens mainly with the 0.8mm nozzles, a factor could be temperature: it requires 4x more heat to melt enough plastic in the same time for a 0.8mm nozzle than for a 0.4mm nozzle (twice the diameter = 4x the surface). So you might want to reduce speed and/or increase temp. Try adjusting these on the fly on a test piece, and watch what happens.
    I will test that. With the last print however you are able to see that the print started well in-between had massive under extrusion and then finished well.
    I would expect a no print at all or well print which is why I started to think that this must be a feeder issue
