tinkergnome 927
The firmware for the "plus" model is a bit different, the repository is this one:
https://github.com/Ultimaker/UM2.1-Firmware
The most important file is "Configuration.h"
From what i read, you want to change the definition of "Z_MAX_POS", and disable the heated buildplate by setting TEMP_SENSOR_BED to zero
Good luck!
1
DidierKlein 729
Hi Andy, welcome on the forum,
Interesting project!
You will need to change the firmware of the machine. Source code can be found here:
https://github.com/Ultimaker/Ultimaker2Marlin
For the rest i'm far from an expert in firmware, maybe @tinkergnome can give you a hint or two
AndyD 0
Thanks a lot Didier!
