Hi, thanks for the answer.
Everything seems fine with the fans and I have the same settings as always. Printed hundred of pieces with no issues.
Underextrusion should be there at the start of the print also right?
Everything goes wrong as soon as the second layer starts. Like the nozzle is not calibrated anymore.
gr5 2,330
Strange. Well it speeds up on the second layer so if your second layer height is similar to the bottom layer (typically bottom layer is .27 in cura and second layer is maybe .1mm but if second layer is more like .2 or .3...) then maybe you are just putting too high a volume of filament through the nozzle per second and it is underextruding (which is kind of what this looks like).
Or it could be the fan. The fan comes on starting the second layer. Maybe it's blowing too much on the print head and cooling it down. Or maybe the fan shroud is touching the heater block (very common problem on UM2s) and when the fan comes on the nozzle temp drops like a rock.
Or it could be the Z screw needs cleaning - although that would not affect the second layer - 3rd layer would be the first possible layer with an issue I think.
