When printing overhangs, the material tends to partially sag (since half of the trace is printed in the air), and it tends to curl up when cooling (since there is nothing below to hold it down). Then the nozzle bumps into these curled up edges. All these effects mess up the sides.
Possible solutions you could experiment with: print as cool as possible, so it melts less. And print in thicker layers, for example 0.3mm instead of 0.1mm, if the model allows it: this may have a big effect. Place a desktop fan at low settings in front of the printer for additional cooling.
Try this on a little test print, so you don't waste too much material and time, until you get the best results.
fbrc8-erin 316
What material are you printing with?
Fan speed?
Did you turn brim on in build plate adhesion?
From the photos it looks like there may be a couple of different things going on.
Nielski55 0
I print with 1,75mm PLA, a fan speed of 100% after the first layer and i hade a raft as build plate adhesion. Since the surface touching the bed is quite small in contrast to the rest of the moddel. I also tried a brim.
