That's a special aluminum for tooling plate right?
I asked lasermaster.co.uk price for laser cutting a plate and for their flatness tolerance. They say the material tolerance for flatness is +- 0.2mm over the face of a whole 1250x2500 sheet. would that be right?
Anyway I will also ask them about the mic6 aluminum.
gr5 2,188
The plastic that holds the screws will be fine. It won't get too hot. I have 6mm aluminum plate and it isn't too heavy but I wish I got the 4mm. Make sure you get MIC6 aluminum.
Because of the weight my wooden ultimaker support arms droop from day to day so I have to relevel often. But they are very solid and the weight is not a problem at all.
