Thank you Smithy
The only thing I don’t get is led off; if I have the glow when Print is completed on they pulse as you described until confirmed as removed and if the pulse when Print is completed is off the leds remain bright until I confirm as removed and then go to a low constant glow.
To be clear; the leds never go off unless I turn the printer off at the switch.
This is not something that just happened but rather something I just noticed.
The picture I included with my thread showing the leds on is while the printer is in ready to print mode after sitting for 6 plus hours.
Thank you again.
Edited by ShadowmanWords added
Smithy 1,145
Glow when print complete is exactly what you see, it is pulsating when print is finished until you remove the object and confirm that. This should notify you visible that your print job has finished.
And normally (on my UM3) the leds are off after the print when setting "only while printing", but only AFTER you removed your objects and confirmation.
