Thanks gr5. I figured it out, someone from another forum pointed me in the right direction. The answer was setting my motors in the right direction relative to my home point. My home is in the right rear, which is not the norm, so a few adjustments were required. This is the link to the document that pretty much explains how everything should be aligned, https://drmrehorst.blogspot.com/2017/08/setting-up-3d-printers-origin.html. I learned quite a bit from it, and fixed my issue.
1
gr5 2,330
Well the M82 and M83 conflict. You need to pick one or the other.
I think the M501 destroys pretty much every setting before it, does it not? Shouldn't it be an M500?
I really don't know this printer. (FT5).
Maybe there is an FT5 forum? If you can get the FT5 to work from some other gcode then you could paste the begining of that gcode into the cura start.gcode section.
It doesn't look like it's responding to the G28 (home) command.
The vibration is where it's moving too far beyond the end of travel.
