Unable to get high speed in outer layer
psykat
Posted · Unable to get high speed in outer layer
Hi I am unable to get more that 10-12mm/s speed for the outer layer in Cura.
I have tried setting 60mm/s for outer layer but still I get only 10-12mm/s (please see screenshot)
What am I doing wrong?
    Thank for your reply.
    Yes. I used the spiralize function - but without that also it seems to be slow compared to set speed.
    How to decide on  the minimum layer time?
    I wouldn't go lower than 3 seconds.  It takes about that long just to get down to 60C and PLA is like putty/clay/plasticine at that temperature.  at 50C PLA is finally hard like pastic.
