ahoeben, Thank you for the reply. I added the"Custom FDM Printer" but my Ender-3 machine doesn't recognize it, what am I doing wrong? the printer works fine from the sd card, do I unplug the sd card before adding the printer? I am going from my laptop to the printer via USB cable.
Again Thanks for the help.
Ctdigger
ahoeben 1,657
The latest 32 bit compatible version that was released by Ultimaker is Cura 2.3.1. That version is about 2 years old, so my memory is a bit foggy. You should be able to add your printer as a "Custom FDM Printer" (from the Other category). But realize that a lot has been changed in the past 2 years!
