Yes I did, 2 files in total but no luck at all! ( 1 file is a tar.gz or something
and the second file is the .sig file )
The printer runs fine for the moment but I'd
like to have the latest firmware.
Maybe try a different USB stick.
Or try to download it again and check if the file is still in that format. Mac Safari tries sometimes to unpack the downloaded file automatically and then it is maybe just a .tar instead of tar.gz
Network install from the printer is no option?
40 minutes ago, Dim3nsioneer said:Maybe try a different USB stick.
Thanks, I will try that!!
18 minutes ago, Smithy said:Or try to download it again and check if the file is still in that format. Mac Safari tries sometimes to unpack the downloaded file automatically and then it is maybe just a .tar instead of tar.gz
Unfortunately I can not connect the printer to internet due to our local network
security configurations!
Can it be done from a PC to the printer?
14 hours ago, Lammertus said:Yes I did, 2 files in total but no luck at all! ( 1 file is a tar.gz or something
Just checked, the files are rootfs-5.1.7.20181023.tar.xz and
rootfs-5.1.7.20181023.tar.xz.sig
Is there a download site for downloading the current and maybe older versions,
just in case of??
26 minutes ago, Lammertus said:Is there a download site for downloading the current and maybe older versions,
just in case of??
https://software.ultimaker.com/releases/firmware/9051/stable/
32 minutes ago, Smithy said:
Thanks a lot Smithy, this just in case of :-)
The URL from Smithy is the same one that the printer accesses when it's downloaded through the network, so it should work. Additionally, could you try to download these files through another browser?
43 minutes ago, WesleyE said:The URL from Smithy is the same one that the printer accesses when it's downloaded through the network, so it should work. Additionally, could you try to download these files through another browser?
Hi WesLeyE,
Thank for helping me with this, I just re-formatted the USB-stick just in case and
downloaded the files again with Iexplorer instead of Chrome.
Now it has installed ok.
Hopefully now it works even better!!
Thanks everybody for helping me with this!
LAmmertus
Great to hear and thanks for reporting back!
Smithy 1,145
Have you copied also the sig file?
