Yeah, but I would like to keep those values locked in place so you can make temporary changes that when you are asked to keep or discard changes, Ones that are locked will always be kept but unlocked ones can be discarded and set back to default.
I have some settings that I never change and would like to be set a certain way whether it's a custom profile or default. So having it locked would be nice. but then sometimes I might make a few small changes depending on the model that can be discarded once that print is done.
nallath 1,067
This is what happens if you put the same value in the field. User changes always override everything.
