Hi gr5
Not sure what you're asking for when you say "slice view". The image labelled "CR-10 print_2" is a larger version of the two. I've included the Cura version.
I've got multiple issues with trying to print this part which I'm sure comes down to my settings. I'm starting to suspect that my Print Setup settings are being included in the gcode for the print because of the Shell Wall Thickness setting.
As you can see in the two actual part images, the skin is just lifting off and the radius corners aren't printing correctly.
Hope that's enough info for you to try and give me some advice.
Thanks.
gr5 1,871
Please show some photos of the part in real life and also in slice view highlighting one problem spot.
