13 minutes ago, Smithy said:Is it possible that the brass you found was from the nozzel? I mean that due the unscrew of the nozzle some brass came off?
UM uses a very high torque for the nozzle and it is not made to take the nozzle off. So the chance is normally very high that you damage your print core if doing so or that the core will leak after putting everything together due to less torque.
Possible but unlikely. The metal was embedded in the melt before unscrewing. Picture added in edited OP.
Smithy 1,090
