I can't because the stl is from heroforge and it is not redistributable 😞
It sounds like maybe the model is supposed to be hollow for the first 16 layers.
Although maybe it's just a bad model. You can repair bad models most easily by passing them through the netfabb free repair service (you have to create an account):
https://service.netfabb.com/login.php
Or if you are lucky you can just go into Cura "mesh fixes" and play with each of those. One of those might fix the problem. But many of these will fill in areas that you want to be open so check carefully in layer view before printing.
Smithy 1,141
Hi
can you please post your Cura project here or the STL file, then we can take a look on it.
