Posted · cleaning nozzles with steel needles?
Thanks! Are you saying that it is not advisable to pass the needle completely through the nozzle? Even if it is a 0.2mm needle going through a 0.4mm nozzle?
    You can definitely pass through the nozzle but don't go so far that you scratch the teflon which is typically at least 2 nozzle heights away from the tip of the nozzle.
    These are acupuncture needles.  They have a pointy tip.  I like hypodermic needles a little better as they have a sharp edge and can scrape the inside of the nozzle tip nicely.
    I have been meaning to cut or grind the tips of my acupuncture needles flat to see if that works better.  Or maybe at a tilt (like hypodermic needles) instead of a point in the center.
    I find a cold pull is usually good enough for cleaning inside a nozzle but if you have a bit of sand or fiber in there then pushing the blockage up into the heat chamber of the nozzle using a needle followed by a cold pull works great.  But in reality this hasn't been an issue the last few years for me.
    Another trick for cleaning a nozzle is to burn everything (remove nozzle from printer first of course) over a gas stove.  Don't let the nozzle get red hot.  Just hot enough to produce black smoke.
    Posted (edited) · cleaning nozzles with steel needles?
    No I meant not digging the needle point into to wall of nozzle, you can push it in as far as you want. I have always done it with the extruder removed otherwise you cannot see if there is anything there.
    Edited by yellowshark
    I use a tiny injection needle, of which I cut off the sharp cutter tip, and rounded off the edges. Sharp edges might damage the soft copper or brass of the nozzle. But even then I take care not to apply a sideways load, so I don't wear out the circular nozzle-opening into an oval.
    Originally the needle was 0.41mm thick, so I sanded it down to 0.39mm, to make it fit into the 0.4mm nozzle opening.
    This is quite soft steel, and will bend rather than break.
    Thank you. This is very useful advice, highly appreciated!
