hi guys
The material is a relatively low shore elastomer, I am not sure of the chemical composition... I managed to have it stick to a sanded aluminium plate and adjusting the bed level.
@gr5 : I tried the dissolved glue but the heat seemed to make the first layer move on the bed
thank you so much for your answers!
gr5 2,192
What material exactly?
I have printed ninjaflex on heated glass bed with extremely thin layer of PVA glue and it was fine. If you use glue stick then take a wet tissue and spread it around evenly. The tissue will remove most of the PVA which is what you want. I'm not sure but I think ninjaflex is TPU.
Smithy 1,144
I have also good experiences with Dimafix and 3DLac spray if something will not stick to the glass. But for TPU material I also use just a very thin layer of PVA glue and it works well.
