On 3/6/2020 at 4:31 PM, LnGk said:Hello! I am also interested in extracting a 3D model of the toolpath from Cura preview section. I am actually interested in a different application: I want to make a nominal/actual 3D geometry comparison with scanned data. Does anyone know what type of surface rendering Cura is using for Gcode preview and if there is any way (plug-in, code or other software) to export or reconstruct the toolpath as a 3D file (STEP, STL)?
So far, I have found this published work (http://dx.doi.org/10.1145/3055186.3055198) that does something similar with CSG shapes union in OpenSCAD, but the full details are not disclosed. It would be great if Cura can perform this directly.
Thank you in advance!
P.S. I though I should use this thread as it is a similar topic, let me know if I should create a new one.
It's actually a bunch of shader rendering tricks that we use. So the model that you want doesn't really exist, sorry.
Smithy 1,144
Hi
I think this is a question for Solidworks, because you need the gcode export of Cura, it is the only file with all the informations you need. So what you want to do is, to import a gcode file in Solidworks and check the slicer result with your stress tools.
But I don't know if Solidworks is able to do that, import a gcode and perform any action on it, I guess no.
nallath 1,123
We don't have any way to do FEA and as far as I know, solid works doesn't have the know-how to do it even if we were able to provide the internal geometry. You would also have to take the speed of the printing (since this also affects the adhesion between layers) into account, which isn't something that's done right now.
LnGk 0
