the model seems indeed perfectly ok without support, but if you ever need "custom" support you can model it in in CAD, and safe the object and the support structure as 2 separate STL's, then just print like a nomal dual extrusion print (without support) and select the 2th nozzle for the custom support structure.
1
Smithy 1,144
Have you tried to print the pipe without support? I think it can work without any support and you don't have to wait to dissolve the PVA which will take hours to days in your case.
pineirod 2
In the description of Thingiverse they suggest not using support, but I was worried about the very top of the tube.
I also took this as an exercise to understand supports better
thanks
