I seem to be stuck with an unloaded filament but can't convince Cura + firmaware to let me print. I had nylon loaded in #2. I've since disabled #2 to print some #1 PLA. If we drop down the printer, it knows there is nothing in #2:
However, I select that configuration (Whilte PLA + none), it doesn't take ... It still thinks there is nylon. This is also in spite of the extruder being disabled (I could go on at length at how bad Cura is when you have a single filament print but two things loaded ... like using the higher bed temp of the two, despite one of them being unused....). I select the config, and it remains convinced nylon is loaded. Then, if I print ...
Short of lying about nylon being loaded, I'm not even sure how to get it to print (though haven't tried that hard)
Basically I cannot convince Cura that nothing is loaded in #2
PK
Edited by PaulK
ahoeben 1,968
Most of my plugins are now available for this beta in the Marketplace.
Two areOne is still awaiting approval from Ultimaker.Note that plugins that are now becoming available in the Marketplace probably will not work with beta 1; they need beta 2.
Edited by ahoebenLink to post
nallath 1,124
Same goes for the barbarian & orientation plugin. They will work with the 4.0.0-BETA-2!
Guest maht
Firmware 5.2 beta was pushed to the S5 testing channel yesterday, so if you have an S5 and Cura 4.0 beta 2, you can test the new Remote printing feature on your S5, and print outside the realms of your local network (as well as some other cool stuff). Feedback encouraged!
