Posted · Round Prints
I just started 3D printing zand i have an issue with getting round prints. When i draw my prints in Solid Egde they appear round and nice. But when i transfer them over to Cura i get edges.
Any Suggestions?
image.thumb.png.240232e76cab2db5aff947ae51a8b9bd.pngimage.thumb.png.9a115610880b56bdee8b65dc8cd57eeb.png
    The problem is with the file export process. I am a solidworks and NX user.  In both programs, there are settings to control the output of STL files when a model is 'saved-as'.  I suspect there are also such settings in solid edge.  Even when you save a mode with higher resolution, the model will be reduced to triangles, they will just be much smaller.  Look for these settings in your save dialogue.
    • Thanks 1
    In DesignSpark Mechanical there are settings for STL-quality: coarse, medium, fine, custom. Coarse gives the same as you show here. Fine is okay for 99% of prints. With "custom" even better results can be got, but then the amount of triangles and thus the file size of the STL go out of the roof. Search for a setting like "STL export options" or something similar.
    • Thanks 1
