Wow -- exactly correct! Why would an experimental setting come as pre-enabled? (rhetorical question)
Thanks, Smithy!
Thanks, Smithy!
42 minutes ago, wourmman said:Why would an experimental setting come as pre-enabled?
That's a good question, but it is not generally pre-enabled, because for me it is not. So I guess it depends on ??? whatever 🙂
I don't think it's standard for any of the ultimaker profiles but maybe for other printers?
Smithy 1,131
Looks like you have enabled Coasting in Cura. Check this setting and uncheck the checkbox if enabled.
