Wow, Thanks a lot.
Great info.
I noticed that you said M92 E98....I assumed that I needed to put a 0 in front of the 98, as in E098 because there are 3 numbers after the E. Is that wrong?
Also, the M500 was something I was not aware of, so are you saying that by adding M500 that the next time I turn on my Ender 3 and print something that was sliced with Cura that the Printer will remember my estep setting?
I was not totally sure what you meant by the second sentence... "Without the M500 it will still remember the setting until you power cycle or do another M92. So:"
I really appreciate the incredibly fast response.
BD
gr5 1,967
M92
As in:
M92 E98
Put this at the top of the gcode file as it runs the gcodes in order from first to last. The printer doesn't know whats at the end of the gcode file until the end of the print.
If you add a M500 then it will save the value after a power cycle. Without the M500 it will still remember the setting until you power cycle or do another M92. So:
M92 E98
M500
That will save the values and then you don't have to mess with steps/mm ever again.
