thanks for the reply!
while something i will definitely try out, i feel it doesn't reply to the question as why all inner walls should disappear? - this IMHO is a bug in cura, since there should be sufficient space and material left to slice walls in the inner of the body after a slight horizontal expansion...
Adam324 12
See my post below on using 'Outer wall inset'. Horizontal expansion essentially just scales the whole design bigger or smaller. 'Outer wall inset' move the outer wall in toward the inner wall a set amount to compensate for a line width that is slightly larger than what you specify.
