Ender 3 Pro Cura settings
broderp
Posted · Ender 3 Pro Cura settings
Hello, I apologize ahead of time if this is not the proper place to post.
I am new to 3D printing and Cura.   I have an Ender 3 Pro and am looking a place to find guidelines and general settings for my machine to input into Cura.  I know this is a loaded question with many factors to consider.
Aside from the general info (bed size, nozzle etc.)  what settings are generally considered best? Is there any other resource available?  With the popularity of the Ender series printers, I'm a bit surprised there was not more to find.
Thank you for any assistance.
I searched the forum for "Ender 3 print settings" and found nothing.  I will admit the format for this forum is not familiar, but I assumed my search criteria should have had some hits.
    • 2 months later...
    Hi buddy, i'm just using the stock profile in cura for the ender3/PLA. The only modifications I have made are adding some start gcode for my bl-touch and modifying the infill settings based on what I'm trying to print. And my stuff comes out great.
    Regards,
    Xomu Kiwi
    You can use the standart settings. But if you want to increase you print quality you should change retraction, temperature and speed settings. These are the most common things I would recomend for a beginner. But you cant change these settings for your printer. They are filament specific. There are enough videos on youtube. Just watch a few of them 😄
    It's already integrated. It's in! But we've just today found an issue with Creality project files from before the merge not working after the merge. Hopefully we can get that fixed before the 4.2 beta or at least before stable.
