Ultimaker 1 factory reset- How
Posted · Ultimaker 1 factory reset- How
Hi
Is there any way to do a factory reset on the um1?
Do I have to flash the marlin software do to a reset?
A lot of people changes the configuration and now nothing works anymore
    I don’t own a UMO but my first question would be can you still connect to it from cura when you connect it to a pc with an USB cable?
    If so you can just update to the latest firmware from cura.
    Yes that's can be done but that's not really a factory reset.
    A lot of parameters were changed during the time and the bed and noozle are completely incorrectly  calibrated.
    Back to the beginning
    There are two ways to perform a factory reset.
    1. if an UltiController is installed, it's in the "Control" menu - "Restore failsafe" and a subsequent "Store memory"
    2. with GCode command M502, followed by M500, sent on a serial console like (e.g.) pronterface
    Bed leveling assistant is integrated in Cura AFAIK (in machine settings)?
    printrun/pronterface/prontrface download:
    http://koti.kapsi.fi/~kliment/printrun/
    Thx a lot. I will try it
        • 4 replies
