My breakaway also tends to have a lot of little curly pieces. I think what makes it a good breakaway is that it doesn’t bond well...but that means it also doesn’t build great structures. Sometimes the support overlaps the part and those strands get commingled into the part...
I’ve found that wider supports seem to work more cleanly, such as when supporting a wide shelf. Those tall, thin supports tend to break off partway through the print.
if you search cur settings for “expansion” you’ll find support horizontal expansion that defaults to 2mm. You might try increasing that and possibly increasing support infill percentage.
i had a small part with a short overhang I was printing in nylon. Cura didn’t put enough support there so I modeled a support block and did it as a 2-color print where the 2nd color was breakaway.
gr5 2,026
That looks pretty typical. I don't think anything is wrong with your BB core. PVA does not stick to itself while still molten as well as PLA. PLA comes out like a liquid rubber band while still hot. PVA comes out like toothpaste, or cement, where it doesn't stick to itself and tiny chunks can fall.
You need to keep PVA super dry. No one seems to get this. You can't just put it in a bag with a little pack of dessicant. You have to keep it at like 10% humidity. Like a dessert. If you leave it on the back of your printer for 4 days it is "ruined" and needs drying again. I usually dry a spool of PVA on my heated bed with the temp set to 80C and with a towel over it overnight. Don't go over 80C or all your PVA will melt. But best to keep it dry with rechargable color changing dessicant. Look that up on ebay. You want boxes of dessicant the size of your fist. Roughly. The dessicant needs to be recharged often. That's why you need the color changing type to know how it's doing.
If it gets wet then it sticks to itself even worse. If it gets VERY wet it makes sizzling noises while printing as you can hear the water boiling. Those steam bubbles get into the PVA and cause problems.
slg02 0
hey, thanks for reply!
Yes that was probably what happened to my PVA as it absorbed some humidity while being stored. And yes, I heard quiet sizzling sounds when filament reached heated core. I'll try and dry out these PVA spools.
How exactly you dry your PVA spools, can you elaborate please? do I need to put something under spool for that, or direct contact with glass is okay?
Still I'm confused on why Breakaway PLA looks so messy, any ideas?
