Good question. I printed the green iPhone stand with the following settings:
- layer height: 0.2
- shells: 0.8
- bottom / top: 0.6
- infill: 20
- speed: 75
- temperature: 225
- filament diameter 2.85
At least for the blue filament I have the same diameter. The white one is larger - 2.94. The other stuff I printed mostly with 0 infill. That might be it. But why on earth would zero infill make it worse? Except there are some complicated corner cases where, without infill the filament contracts/expands differently when cooling thus amplyfing z-wobble problems. Weird...
gr5 1,858
Interesting!!!
This makes me think there is nothing wrong with your z stage. If that green part can look so perfect.
What was different about the green part? Did you print it much slower so that the machine shook less? Or slower could have caused more even extruding? Maybe the filament diameter for blue and white is too large and gets "stuck" in the tube? Maybe something wrong with the slicer? Maybe something to do with infill?
