Check these two parameters:
support X/Y Distance (defaults to .7mm I think)
minimum Support X/Y Distance (defaults to 0.2mm I think)
Also look at the part in "prepare" mode (at the top of the screen) and rotate the part to look under that overhang. Is it red? If not then the "normals" in the STL file are backwards. "normals" in the STL file tell cura which is the outside and inside of the part and are used to figure out where to put support but not relied on so much during the slicing step when things are 2 dimensional.
What CAD software did you use to create this? If sketchup then it's trivial to swap the normals on this overhang. Right click and choose "reverse faces".
burtoogle 510
Hello @latreides, could you please save the project file (.3mf) and attach to this thread. Thanks.
