What I did was test out the full limits of the printing capacity. And figured out how much actual print area was available for use. The issue I believe is the print head. It needs sufficient space for the nozzle switch. I eventually had to resize the print in order to make it fit inside. I am using cura 4.1. But I essentially I think the issue is that the printer has a set limiter.
getting max volume out of cura
set "travel avoid distance" to zero.
disable brim and skirt both!
more settings/details here:
https://ultimaker.com/en/resources/44677-maximum-build-volume-ultimaker-2-plus-ultimaker-3
pdzamore 1
I haven't tried to print up to the limits of the y-axis, but I have the same problem with the x-axis: I cannot print an object larger than 321 mm. Are you using Cura 4.1? That is where I am blocked from using the full build area. I was thinking of changing the machine settings to increase the build plate dimensions. Have you tried that? Do you know whether the issue is the printer or the slicer software?
