No.
The Mintemp is trigggered when I insert the TC in the heaterblock. When I insert it the themp starts to drop. If I wiggle it it goes up and down. I think the same thing happend with the original TC and TCpcb. It was ok when the bot lay on its side, but triggered when I turned it to upright position.
I have a Makerbot TOM, and in the assembly wiki, they point out that the TC should be wrapped with kapton tape for insulation before attached to the heatblock....
Johan
owen 19
The mounting screw isn't shorting it out is it?
