5 hours ago, QBall1977 said:Gary,
Can you please provide a little more information on your setup.
what versions of RaspberryPi are you using?
what Operating System (and version) are you using?
how is the memory split setup on your Pi?
are you running the app image as admin (sudo)?
which profile if any did you choose in Cura?
have you tried resetting all the settings? (I think there’s a folder In you home directory(.config/Cura) ???
it runs very well on a 4B, Buster with 128 memory split, although menus can take a second or two to load!
Thanks QBall77
Hopefully this will give you a better idea:
Raspbery Pi Model 4 B+ 2GB (though it was the same on an 8GB)
Raspbian Buster updated and fully upgraded before this
Version info:
pi@raspberrypi:~ $ cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
NAME="Raspbian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
VERSION_CODENAME=buster
Logged into the machine as default Pi user, launched by user Pi
Appimage started from X11 desktop. Permission set "All users may execute"
Memory split : tried 128 and 256MB but same with both
I have reset Cura to default and re-configured
Printer profile set to suit my Creality Ender 3, default
Here's an image of the UI, all the buttons and menus are just black background. A user interface problem but not sure how this is built or created?
Top Posters In This Topic
44
9
8
6
Popular Days
Jul 23
8
Aug 2
8
May 12
8
May 3
6
burtoogle 44 posts
icare 9 posts
stevepos 8 posts
gr5 6 posts
Popular Days
Jul 23 2020
Aug 2 2019
May 12 2020
May 3 2020
Popular Posts
burtoogle
Now available is a Linux AppImage that runs on an armhf system (e.g. a Pi 4). It has received minimal testing but it does appear to work (I sliced a benchy OK!). Obviously, even the amazin
burtoogle
I have managed to workaround the various limitations and bugs in the graphic library and now have quite a nice display. It still has some compromises compared to the other builds (Linux/Mac/Windows) a
burtoogle
Here's the system it was built on. Very nice case from thingiverse sliced without top/bottom skins, just gyroid infill. The SSD wasn't actually used during the build as all files were on the SD card.
Posted Images
QBall1977 0
Gary,
