OK. I know this is going to be a long shot, but it sure would be nice if it works. First I'm going to try to get this to work on my ARM64 Lenovo Chromebook C330 with Linux emulation - totally encouraged by the comment in the ReadMe that says "the AppImages also run on Chromebooks that support Linux apps" though I understand that's the x86_64 architecture - but still - hopeful! Anyway, I have downloaded and set the execute bits on Cura-mb-master-aarch64-20201121.AppImage and when I try to execute it, this happens:
steinhelten@penguin:~$ ./Cura-mb-master-aarch64-20201121.AppImage
./Cura-mb-master-aarch64-20201121.AppImage: error while loading shared libraries: libz.so: cannot open shared object file: No such file or directory
I tried to use apt to load libraries, but both were not found:
steinhelten@penguin:~$ sudo apt-get install libgles-dev
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Unable to locate package libgles-dev
steinhelten@penguin:~$ sudo apt-get install libz
E: Unable to locate package libz
So - I know this is a long shot, but if anyone has a suggestion for me, I'd like to try it.
Failing this - what about the X11 remote display capabilities of running the program on my RPI4 4GB but having the display be my ChromeBook? I think, in theory, that should be possible, if I ever figure out the permissions correctly, and figure out how to set the DISPLAY environment variable correctly...
Top Posters In This Topic
44
9
8
6
Popular Days
Jul 23
8
Aug 2
8
May 12
8
May 3
6
burtoogle 44 posts
icare 9 posts
stevepos 8 posts
gr5 6 posts
Popular Days
Jul 23 2020
Aug 2 2019
May 12 2020
May 3 2020
Popular Posts
burtoogle
Now available is a Linux AppImage that runs on an armhf system (e.g. a Pi 4). It has received minimal testing but it does appear to work (I sliced a benchy OK!). Obviously, even the amazin
burtoogle
I have managed to workaround the various limitations and bugs in the graphic library and now have quite a nice display. It still has some compromises compared to the other builds (Linux/Mac/Windows) a
burtoogle
Here's the system it was built on. Very nice case from thingiverse sliced without top/bottom skins, just gyroid infill. The SSD wasn't actually used during the build as all files were on the SD card.
Posted Images
Stirling 0
Hi
newb here so im probably missing somthing simple but how do you run/execute the CuraEngine.exe file? as far as I know .exe files are only executeable on windows.
And also is that the only file I would need to download or is there other stuff that is needed?
Cheers
