can I adjust Cura to print the same directions, shell and infill, on each layer?
Posted
· can I adjust Cura to print the same directions, shell and infill, on each layer?
You can set the direction of skin and infill lines. By default, the skin lines are at +45 and -45 degrees but if you change the top/bottom line directions to [0] then all the skin lines will be printed at 0 degrees. Similar for infill. Hope this helps.
Posted
Ah, I just realised that you probably want all the lines printed in the same direction (i.e. bottom to top) but even when setting the directions as I mention above, alternate lines are printed in opposite directions (i.e. first line bottom to top, 2nd line top to bottom, etc.)
burtoogle 509
burtoogle 509
gr5 2,070
I believe outer shells are always CCW and inner shells (holes) are CW. I don't think it's possible to change this.
JTBrown 0
Thanks for your help guys
