Continued printing issues
Posted · Continued printing issues
Hey guys,
I've been trying to fix this for a while- I've taken apart the feed motor, cleaned out bowden tubes, replaced nozzles, hot and cold pull, levelled the print bed, replaced material, basically everything I can think of. A print will start fine and then be unable to complete subsequent layers as you can see in this photo:
I think it's a feed issue- either the nozzle is blocked or the feed motor has an issue, as i can force the material through near the feed motor and it seems to resume correct printing but resorts back to this intermittent printing pattern soon after. I have no idea why it's happening. I'm using Amazon's 2.85mm PLA using the settings recommended by them ( 215c printing temp, 50c plate temp). I've given up trying to figure this out at this point and would love it if anyone here could shed any light on it?
On the printer when the material is loaded, i select PLA and then in Cura I put the settings listed above in. When i send to print i get a message saying there's a difference in printer and cura settings and i Override- could this be the source of the issue?
    What happens if you start a print immediately after this happens?
    Does it then print normal in the beginning or are there then problems from the start?
    I had similar issues. For me the problem was the lever, which presses the material against the knurled wheel of the feeder. It came apart and the feeding wasn't correct anymore. After a replacement it now works fine
    See also this thread:
    Thanks for the reply. This does look similar. I did take apart the feeder motor and it seemed fine but i will try again.
    I just sent another print immediately and nothing's coming out. I'm sure it's the feeder eating into the material, but i also know that the nozzle gets sort of blocked- when i do a hot pull and initially insert the pla to clear it out, i need to push quite hard and there's a pop sound before a load of pla pours out, so something's definitely getting stuck in there somehow.
    You have random severe underextrusion.  Below is a list of underextrusion causes but many of them only cause partial underextrusion.  Here are some ones to pay the most attention to:
    #1 - it speeds up as it goes higher levels so maybe you are printing too fast.  Seems unlikely
    #19 - remove spool from printer and test the filament by trying to break it.  It should not snap before bending 90 degrees
    #16 - your symptoms completely fit this one!
    #8 - a common problem for cheap filament - get a micrometer if you don't have one - $10 on ebay
    #21 - that's the first thing I thought of
    #14 - have you ever printed glowfill or CF or GF filament?
    #20 is worth looking into
    #18 - it's definitely not this one
    CAUSES FOR UNDEREXTRUSION ON UM3 AND HOW TO TEST FOR THEM AND REMEDY THEM
    As far as underextrusion causes - there's just so damn many.  none of the issues seem to cause more than 20% of problems so you need to know the top 5 issues to cover 75% of the possibilities and 1/4 people still won't have the right issue.  Some of the top issues:
    1) Print slower and hotter!  Here are top recommended speeds for .2mm layers (twice as fast for .1mm layers) and .4mm nozzle:
    20mm/sec at 200C
    30mm/sec at 210C
    40mm/sec at 225C
    50mm/sec at 240C
    The printer can do double these speeds but with huge difficulty and usually with a loss in part quality due to underextrusion.  Different colors print best at quite different temperatures and due to imperfect temp sensors, some printers print 10C cool so use these values as an initial starting guideline and if you are still underextruding try raising the temp.  But don't go over 240C with PLA.
    Note that your "print speed" may be 40mm/sec but it may be printing infill at 80mm/sec so CHECK ALL SPEEDS.
    2) Line Width larger than nozzle.  In cura 3.X search in settings for all line widths.  If any of them are larger than the nozzle diameter this can cause underextrusion.  There are 8 of these in cura 3.2.1.
    3) Curved filament at end of spool - if you are past half way on spool, try a fresh spool as a test.
    4) curved angle feeding into feeder - put the filament on the floor -makes a MASSIVE difference.
    5) Bad core.  Try a different core.  It could be clogged, or something more complex like the temp sensor in the core.
    5a) clogged nozzle - the number one most suspected problem of course.  Sometimes a grain of sand gets in there but that's more obvious (it just won't print).  Atomic method (cold pull) is the cure - from the menu do a few cold pulls.  The result should be filament that is the exact shape of the interior of the nozzle including the tiny passage to the tip of the nozzle.  If it doesn't look like that you need to pull at a colder temperature.  You can do it manually instead of through the menu if it's not working right but learn through the menu initially.  95C is roughly the correct "cold" temperature for PLA.  Higher temps for other filaments. Simpler cold pull (3dsolex cores only - doesn't work on ultimaker cores because you can't remove the nozzle): https://www.youtube.com/watch?v=u07m3HTNyEg
    5b) Temp Sensor bad - even the good ones vary by +/- 5C and bad ones can be any amount off - they usually read high and a working sensor can (rarely) fail high slowly over time.  Meaning the sensor thinks you are at 220C but actually you are at 170C.  At 170C the plastic is so viscous it can barely get out of the nozzle.  You can verify your temp sensor using this simple video at youtube - on you tube search for this: mrZbX-SfftU
    6) feeder spring issues - too tight, too loose.  You want the tension such that you can clearly see the diamond pattern biting into the filament.  You want to see at least 2 columns of diamonds.  4 columns is too much.  You usually want the tension in the center.
    7) Other feeder issues, one of the nuts holding UM2 and UM3 together often interferes with the feeder motor tilting it enough so that it still works but not very well.  Other things that tilt the feeder motor, sleeve misaligned so it doesn't get a good grip.  Gunk clogging the mechanism in there.
    😎 Filament diameter too big - 3mm is too much.  3mm filament is usually 2.85mm nominal or sometimes 2.9mm +/- .05.  But some manufacturers (especially in china) make true 3.0mm filament with a tolerance of .1mm which is useless in an Ultimaker.  It will print for a few meters and then clog so tight in the bowden you will have to remove the bowden from both ends to get the filament out.  Throw that filament in the trash!  It will save you weeks of pain
    8b) Something wedged in with the filament.  I was setting up 5 printers at once and ran filament change on all of them.  One was slowly moving the filament through the tube and was almost to the head when I pushed the button and it sped up and ground the filament badly.  I didn't think it was a problem and went ahead and printed something but there was a ground up spot followed by a flap of filament that  got jammed in the bowden tube.  Having the wedgebot (link below) helps you feel this with your hand by sliding the filament through the bowden a bit to see if it is stuck.
    https://www.youmagine.com/designs/wedgebot-for-ultimaker2
    9) Extruder mis calibrated.  Maybe you changed equipment or a wire fell off.  Try commanding the filament to move exactly 100mm and then measureing with a ruler that it moved 100mm within 10% accuracy.  If not adjust the steps/mm (this is done by editing a json file on the UM3).
    10) Z axis steps/mm.  it's easier than you might think to double or half the Z axis movement as there is a jumper on the circuit board that can be added or removed.  If the Z axis is moving 2X you will get 50% underextrusion.  Your parts will also be 2X as tall.
    11) Crimped bowden.  At least one person had an issue where the bowden was crimped a bit too much at the feeder end although the printer worked fine when new it eventually got worse and had underextrusion on random layers.  it's easy to pull the bowden out of the feeder end and examine it.  Similar to 8b above - use the wedgebot to feel how much friction there is in the bowden.
    12) Worn Bowden.  After a lot of printing (or a little printing with abrasive filaments) the bowden resistance can be significant. It's easy to test by removing it completely from the machine and inserting some filament through it while one person holds it in the U shape.  Preferably insert filament that has the pattern from the feeder and fight the movement by applying 2kg force on both ends at the same time and then seeing how much harder you have to push it on top of 1kg force.  UM2 feeders can push with 5kg force.  UM3 can push quite a bit more.  5kg is plenty.
    13) Small nozzle.  Rumor has it some of the .4mm nozzles are closer to .35mm.  Not sure if this is actually true.  I'm a bit skeptical but try a .6mm nozzle maybe.  This shouldn't be a problem on the UM3 which has very good quality control but try a different core.
    14) CF filament.  The knurled sleeve in the extruder can get ground down smooth - particularly from carbon fill.  4 spools of CF will destroy not just nozzles but the knurled sleeve also.  Look at it visually where the filament touches the "pyramids".  Make sure the pyramids are sharp.
    15) Hot feeder driver.  I've seen a more recent problem in the forums (>=2015) where people's stepper drivers get too hot - this is mostly a problem with the Z axis but also with the feeder.  The high temps means the driver appears to shut down for a well under a second - there is a temp sensor built into the driver chip.  The solution from Ultimaker for the um2 is that they lowered all the currents to their stepper drivers in the newer firmware.  Another solution is to remove the cover and use desk fan to get a tiny bit of air movement under there.  This doesn't seem to be a problem on UM3 even though it's the exact same circuitry but they lowered the current in the firmware.  But it's worth considering if air temp is 30C or hotter.  It would probably happen only after printing for a while (air heats up slowly under the printer).
    16) third fan broken.  This tends to cause complete non-extrusion part way through a print.  In the door of the head.  You can hear it come on when cores get above 40C.  Without this fan several things can go wrong.  It can take a while as usually you also need several retractions to carry the heat upwards.  There are a few failure mechanisms and I don't understand them all.  One of them is probably that the molten PLA spreads out above the teflon and sticks to the metal in a core or fills the gap at the base of the bowden in UM2.  Later it cools enough to keep the filament from moving up or down.
    17) Spiralize/vase mode.  This is a rarely used feature of Cura but you might have left it on by accident?  In this mode the wall of your part is printed in a single pass.  So if you have a .4mm core and the wall is .8mm thick it will try to over extrude by 2X.  This is difficult to do and may instead lead to underextrusion.
    18) too many retractions (this causes complete failure) - if you have too many retractions on the same piece of filament you can grind it to dust.  10 is usually safe.  20 is in the danger zone.  50 should guarantee failure.  You can tell cura to limit retractions to 10 per a given spot of filament.  Do this by setting "maximum retration count" to 10 and "minimum extrusion distance" to your retraction distance (4.5mm for UM2 and 6.5 for UM3).
    19) Brittle filament.  Espciallty with older PLA but even brand new pla can do this.  If you unspool some (for example if it's in the bowden) for many hours (e.g. 10 hours) it can get extremely brittle and it can snap off into multiple pieces in the bowden.  It's not obvious if you don't look for this.  Then it starts printing just fine and at some point one of those pieces reaches the print head and gets hung up somewhere and the printer suddenly stops extruding for now apparent reason.  This usually happens within the first meter of filament - once you get to printing the filament that was recently on the spool it should be fine from then on.
    20) The "plus" feeder can have an issue where the filament doesn't sit properly for one print and it permanently damages the arm inside the feeder as shown by this photo - the hole is ground down asymetrically: http://gr5.org/plus_feeder_issue.jpg
    21) Filament tangle - the end of the filament can get tucked under a loop on the spool and this tangle can propagate from then forever to the end of the spool until you fix it.  It will cause many many jam ups and slow then halt extrusion.  Repeatedly.  The fix is to remove the filament from the printer, unroll a few meters and respool and put back on the printer.  Never let go of the end of the filament spool until it's in the bowden.
    • Thanks 1
    Posted (edited) · Continued printing issues
    BINGO
    You're a genius dude, thanks so much for your post. I'm 99% sure this is it (or at least part of the problem)- when i originally saw the arm had this dip in it I thought it must be part of the design but on removing it, it's clearly been worn out.
    I take it I need to contact a local reseller to source this part? Is there a more durable alternative version out there?
    Edited by hughwyeth
    the part-numbers are 1967 (the worn-out half on the photo) and 1968.
    One also realy useful solution would be this:
    http://www.youmagine.com/designs/ultimaker-3-extruder-lever-mod
    Works pretty well for me.
    Regards
    14 hours ago, Enigma_M4 said:
    Regards
    Thanks for this.
    I realise that because I'm using amazons's PLA it doesn't site on the spool holder that well and the PLA is being fed into the motor at an angle. I switched it's place so it sits in material slot 1 on the spool holder instead of 2 and it managed to complete the print with no issue. I'm now trying to print this lever to see if that fixes the issue and will try and replace the worn lever with this one. Thanks!
    I had a similar issue with MatterHackers PLA. The spool is a little to thick to place in the spool holder/guide for material 1 (the one furthest from the printer body. As such I couldn’t use the guide. It seemed to be feeding OK but during the print, the MH filament slipped over the rim and was being pulled between the coils of the breakaway support material in the inner (#2) position. This caused it to bind in the counter-rotating spool of material 2.
    I have found that when printing without support, I can use the wide spool in position 2 just fine. I have successfully printed with support material in position 1 using the holder/guide.
    Right I think we have a similar issue. The guide definitely helps as it stops the material crossing over the other spool and rubbing against everything.
    On 7/18/2019 at 7:31 PM, Enigma_M4 said:
    Regards
    Hey- i have printed this new lever, but I'm a bit worried about disassembling the current lever. Although it's clearly not fit for purpose, is it possible to take it apart without breaking it?
    Hi, hughwyeth,
    taking apart the original lever is no big thing, if done carefully.
    At first, the cross-shaped clamp at the "lever"-side should gently be disconnected (be careful not to break the tabs!). I used a flat screwdriver blade (the one of a victorinox swiss knive worked best for me) put between the two halves and gently pressed the two opposite tabs with tweezers, just enough for them to disengage the two halves at this point. You should take care to not cant the parts to much. Then the axle (press-fit) of the bearing should be disconnected by using a flat screwdriver between the not-worn side of your photo above and the bearing. The inner part of the axle (at part 1968) should slide off the outer part (at part 1967) where the bearing sits on.
    My first attempt was successful while working with care; disassembling the second lever, I broke one of the spring-parts because of insufficient patience...
    I hope the description is understandable and useful, unfortunately I have no pictures for clarification.
    Regards
    Hi, hughwyeth,
    Regards
    That's great, thanks so much!
