Ultimaker 3 cannot be contacted through wifi after around 30 minutes
Pygex
Posted · Ultimaker 3 cannot be contacted through wifi after around 30 minutes
Hi, I just bought an Ultimaker 3 and installed the newest firmware and I have the Cura 4.2 installed. The wifi setup worked and the printer is connected to wifi. However, after around 30 minutes or so, the printer cannot be contacted through wifi even though it says it has a connection to the wifi. I cannot even connect trough the browser to the printer when this happens. This is happening constantly to me.
The current workaround seems to be to restart the printer when this happens but this is quite annoying especially when doing a lot of test prints for small parts and doing minor tweaking to the parts.
Any help?
    I just setup a UM3 Extended. Upgraded the firmware via USB. And I am unable to complete wifi setup. It creates an access point I cannot connect to. I've tried using an iPhone, 2 Android phones, and a Macbook Pro and they all fail to connect to the access point my Ultimaker created.
    • 4 months later...
    Any help?
    Pygex, I am having the same issue!  I have searched everywhere and posted on a few different threads without much luck.  Just this week I discovered the bug has something to do with the tool change.  That would explain why it dies after 20-30 minutes.  The first layer!  This week I printed a few times without using core 2 and it has stayed connected almost all week.  It is the first time I have kept it connected in months. Please try a few prints without a tool change and reply back...  My BB print core two is still installed but I just leave it empty and it is disabled in cura (4.4).
