Well, actually i see no over extrusion... looks like a "healed" cut. The walls are only 2 perimeters by default (which is too thin). But there is no surplus material.
I will reprint the last position to see, if there is a mechanical collision. There is no way for Extruder 1 to reach the entire area of the model, the print is cutted.
After stopping the print, i raised the build plate and moved the head to the print. The head is 1mm away from the chassis. Nozzle 1 is still 1-2cm away from the sliced positions (red vertical line). The right nozzle could help... kidding. Maybe the bounding box is too small?
Edited by dxp
Reprinted and pictures added.
nallath 1,125
Well, the slicing preview looks fine. The one reason we could come up with how this happens is that you head couldn't move that far and it just squished the lines there, but that would mean you'd see a fair bit of over extrusion.
