In case GR5's download ever goes down, I've made a mirror here too: http://dulek.net/work/Ultimaker_Cura-15.04.06.exe
Edited by ghostkeeperFix link not actually linking.
Edited by ghostkeeperDoes anyone have a Mac version of the 15.04.06 Cura?
Yeah I'll be a bit more thorough, also including 2.3.1 which was the latest 32-bit release:
Great, thanks a lot!
Using on one of my computer the Cura Master 4.6 32 bits release made by Mark Burton aka @burtoogle
https://www.dropbox.com/sh/s43vqzmi4d2bqe2/AABccoglNb8rVmEgN88uSMDpa/Windows-32
Working fine ( just an issue with the version of OpenGL on this hardware but this is normal as it is an old computer)
Edited by Cuq
On 7/24/2020 at 1:46 PM, ghostkeeper said:Yeah I'll be a bit more thorough, also including 2.3.1 which was the latest 32-bit release:
- http://dulek.net/work/Cura-15.04.06.exe
- http://dulek.net/work/Cura-15.04.06-Darwin.dmg
- http://dulek.net/work/Cura-15.04.06-Linux_amd64.deb
- http://dulek.net/work/Cura-15.04.06-Linux_i386.deb
- http://dulek.net/work/Cura-2.3.1-win32.exe
- http://dulek.net/work/Cura-2.3.1-win64.exe
- http://dulek.net/work/Cura-2.3.1-Darwin.dmg
- http://dulek.net/work/Cura-2.3.1.AppImage
Thanks for sharing, Ghostkeeper!.
BTW, Does anybody know which Debian/Ubuntu version should be used with the above 15.04.6?
I tried to install it under Mint 20 Ulyana and the installer tells it cannot fulfill the dependencies...
Also with Ubuntu Focal Fossa and Tahr. After years using it on Windows and having tried most of the current advanced slicers, 15.04.6 still gives me the best printing times, and I don't need all those bells and whistles for what I'm doing.
Thanks in advance.
Jes.
The 15.04.06 Debian archive specifies that it requires the following packages:
I don't know in how far those are still maintained for modern Ubuntu or Mint versions. You'll probably still be able to find them online somewhere but maybe not in apt. These are for Python 2, mind you, which has reached end-of-life.
On 11/11/2020 at 2:49 AM, ghostkeeper said:The 15.04.06 Debian archive specifies that it requires the following packages:
- python-wxgtk2.8 or python-wxgtk3.0
- python-opengl
- python-serial
- python-numpy
Thanks a lot. I've been trying several different older distros and I've found out that Xubuntu 18.04 LTS installs okay the above mentioned .deb file and covers all dependencies.
On 11/19/2020 at 7:38 AM, jesito said:Thanks a lot. I've been trying several different older distros and I've found out that Xubuntu 18.04 LTS installs okay the above mentioned .deb file and covers all dependencies.
Thanks for adding this, I got Cura up and on Xubuntu but it hangs at "Opening Serial port" on the Pronterface UI. Was there anything else you needed to do?
On 12/28/2020 at 4:39 AM, scio said:Thanks for adding this, I got Cura up and on Xubuntu but it hangs at "Opening Serial port" on the Pronterface UI. Was there anything else you needed to do?
Sorry to be so late.
I first installed printrun and Arduino 1.8.13 and then Cura and everything went fine.
dkelley01 0
Windows Cura 15.04.06 is the only version that I can get to directly (USB) print to my Anet A8 printer. I mistakenly deleted it while installing a newer version. I have reinstalled 15.04.06 but now am having trouble with having the system recognize my progress plugin. I copied it in Cura_15.04.06/plugins directory but when I look at the Plugins tab to select it, it is not listed; only pauseAtZ.py and TweakAtZ.py. If I click the Open plugin location button at the bottom of the Plugins tab I see it listed with the other 2. I am kinda at a loss as to how to select and activate it. It has been a long time since I set this up originally so maybe there is something I am missing.
Thanks for any help.
