29 minutes ago, gr5 said:That seems extremely specific - that underextrusion. It goes from good extrusion to massive (maybe only 20% extrusion) underextrusion (80% less than normal). Well first thing to try is to slow it down. You can experiment live printing - most printers have a TUNE menu while it's printing where you can reduce the print speed to say 50%.
By default I think cura prints infill at 2X speed so it could be this is where it switches from infill to outer wall and it takes a few seconds to get back up to pressure. It could be your infill is even worse underextruded.
I'd look at the part in preview mode in cura carefully to see what's going on here. use the "play" feature and the horizontal scroll to see exactly the path the head makes.
Now that you say that, i think the problem might be related with another problem i have, where as soon as the hot end gets hot filament starts to extrude by itself, i know this is a normal thing to happen, but it extrudes quite a lot of filament, and it does this everytime, so filament comes out the nozzle even when its not supposed to, when the head is travelling for example.
gr5 2,330
