More likely I'm thinking something is broken in your UM3 print head. Try putting other cores into the right side. Do they go up and down when you slide the lever?
1
Thanks. I´ve tried to disassemble just the clear part and the spring looks good. Just the black piece is a little bit loose, but this only affects when you load the printcore right? when the printer is working the black piece is unusefull.
The print head also looks good. I have no idea what is happening. So I attach two pictures with the lift switch up and down. Maybe you can see what is wrong here. (I know it's not the cleanest print head 😅)
Thank you so much
I don´t have any other printcore to test by the way
On 9/16/2019 at 6:55 PM, gr5 said:More likely I'm thinking something is broken in your UM3 print head. Try putting other cores into the right side. Do they go up and down when you slide the lever?
Any other idea?
gr5 1,841
Instead of just using one hand, try using the other hand to squeeze from the nozzle to the clear part.
Slide it up and down many times. Where is it sticking? The spring can get jammed and start to come out of the clear part.
Taking the clear part and spring off is easy. Try doing that and putting it back together. Here is a detailed video of taking your core apart but you only need to remove the clear part so it's quite simple.
Full disassembly is really a last resort and can destroy your core but taking off the clear part is simple.
