It could've been the case if I didn't get the same result 3 times in a row. I tried to change settings from 0.15mm to 0.2mm, Infill pattern, but that didn't change anything.
I am starting to suspect that something is wrong with my Y axis positioning, but it doesn't happen in all circumstances, just in some special cases like this one. I am also having problems with bottom layer not touching some of the walls, leaving gaps very noticeable with Concentric fill pattern and to a lesser extend with Lines filling pattern (on the image of the fork a gap in filling the top layer can be seen too). This also seems to be Y positioning related.
For some reason it all happens only with ABS filament. With PLA everything was just fine and I didn't have such problems, so I cannot figure out if it is something with my printer or ABS print settings.
I lubricated hotbed sliding bearing and it helped a little, I am planning to order and replace timing belts and print Y-belt tensioner.
If the problem only occurs with ABS and not with PLA, I'd think you have a settings problem, not a hardware problem.
(Trying to think along)
Umo_Alex 4
Can't judge from the picture, but did the right arm come off the bed a bit?
In that case you have an adhesion problem.
