oh, my plan is to edit the gcode to control the 3d printer, that's why i download the repetier, any suggestions?
You can save the GCode , edit the file and then copy it to the USB stick and print from the stick.
It should also be possible to load the GCode back to Cura to send it via network.
tinkergnome 918
@yuanyuan you can take a look at the API - a link to the documentation is on the "homepage" of the printer. I guess that repetier host doesn't support the Ultimaker API.
And there's the "sendgcode" tool on the printer itself (accessible in developer mode).
This older post may be helpful for you:
thanks guys i give up connecting repetier with ultimaker now, instead work with the gcode file and load back to cura....
Smithy 1,114
It is not possible. The network connection is only working for Cura.
