Hi, wondering if this fixed it for you? I'm having a similar problem:
I'm printing 25 or so of the same 19hr file, PLA on a 0.6mm nozzle. While I was still prototyping, I had a nasty leakage which I cleaned up, but the extrusion has never been as good. On Thursday I finished a print and went to change the filament, and the extrusion, after initially coming out fine, went down to almost zero.
At first the filament extrudes fine, then after after 30secs it becomes very very slow. The feeder starts clicking and grinding as there's nowhere for the filament to go. (See pic)
- worked through the extrusion problems list
- tried various filaments including ones I've used before, new and old
- atomic clean several times
- dismantled and cleaned Bondtech feeder
- cleaned and inspected Bowden tube
- I changed the PTFE coupler a few weeks ago, but am getting a new TFM tomorrow just in case
- cleaned the fan and heatsink
Any other suggestions? I'm getting pretty desperate - need to have these done by next week!
P.s. I've always had atomic cleans that look like this - is this normal? I've never seen anyone else's looking like this.
Edited by silver-girlcorrection
1
geert_2 553
Have you checked these?
- Check if the little nozzle-cooling fan at the back of the head still works? If not, or if too slow, this would cause the heat to travel up into the filament, soften it, and make it hard to get through the teflon coupler. Sometimes filament strings and hairs get sucked into it, slowing it down.
- Does the feeder wheel not slip on the drive axis? Write a colored mark on both, and see if they stay aligned? I have read that this occasionally happens.
- With a fine needle (with rounded edges so you don't damage the nozzle) gently and carefully poke through the nozzle?
- Bad filament that is too hard to unroll near the end of the spool? This could act as a very strong spring, trying to pull the rolled-off filament back onto the spool. Also, filament with a too tight bending radius causes very high friction in the bowden tube and in the nozzle. This is why near the end of a PLA spool, I manually unroll a few meters of filament, straighten it, and roll it back onto the spool very loosely.
- Bad filament with incorrect (too thick) diameter?
- When manually heating the nozzle, I guess the temperature readings are okay and stable? But if you can easily push filemant through manually, it should be okay.
PS: if you would like a more gently method of atomic pulls, without brutal pulling and risk of displacing nozzle-components or bending rods, you might try my method: disconnect bowden tube at front, manually heat the nozzle, manually insert and extrude some material (preferably PLA), let cool down very well until at room temp (blow compressed air to speed this up, if available), then gently wiggle and rotate the filament to dislodge dirt, heat up again to 70°C, and gently rotate while gently pulling the filament out. No brute force. For me this works equally well as the traditional atomic pulls, but it is easier on the machine.
For the full manual and photos, see (and then scroll down a bit):
https://www.uantwerpen.be/nl/personeel/geert-keteleer/manuals/
PyramidHead76 0
Thanks for your detailed suggestions. I think this was the key one, or at least started me on a chain of cooling-related things & it seems to be working again now.
Although the fan *was* working, both it and the heatsink were pretty dirty. I took it all apart, cleaned it up with IPA (when cold, obviously), and while I was at it, added some fresh thermal paste around the isolator, and the equivalent aluminium piece connected to the top of the PTFE piece on a 2+.
Before doing that, I noticed that your slow pull technique, and an earlier 'atomic' pull resulted in a almost-break high up the filament where I wouldn't expect one to be (see pic) - I guess what I was seeing here was that there was too much heat up above the PFTE break, and that was probably causing everything to go wrong at the first retract?
Anyway, I'll see how it goes...
